Replacement ear pads for Logitech headset
Drifter
Vereeniging
Where can I find them. All sites I found just mention that they are easy replaceable, but I cant find any listing for the ear pads alone. It's the H390 ones. 981-000406-L
Good luck, I have a H150 headset - cheap (~R200 at the time) and nice for VOIP at work etc. Really not a bad headset, but the foam ear pads are gone and it's nigh impossible to get replacements.
Only ones I've found so far is via Chinese sites. Interested if you find some.
