klasvaakie
- Oct 26, 2008
Ok...I run vista ultimate 32 bit service pack 1.
This is a new install and I used to run on xp and it worked perfectly. I use version 1.0 of route sentry.
My router is a billion bipac 7300.
When I run on another computer without route sentry and now PPOE connection (dialup) it reads the routed connection just FINE.
Now, my problem is, my vista machine does not route through that my lan connection AT ALL. Also, for some reason it keeps dropping the my dialup connection every once in a while...which is odd.
This is my log
10/11/2008 12:20:00 ERROR: The operation completed successfully, (0.0.0.0,0.0.0.0,192.168.1.254,1,8) 160
10/11/2008 12:20:00 Creating routing table
10/11/2008 12:20:01 Finished creating routing table
10/11/2008 12:20:11 ERROR: The operation completed successfully, (0.0.0.0,0.0.0.0,0.0.0.0,1,8) 160
10/11/2008 12:20:11 Creating routing table
10/11/2008 12:20:12 Finished creating routing table
Can any1 tell me what I am doing wrong...pls also use small words...when it comes to networks etc I am a complete and utter total NOOB
This is my log
