Router for wireless network
APoc184
Tshwanetoria
Im finally ditching my MTN 3G and getting ADSL. What router should I get??
I want something really simple as I want to create a wireless connection for only one connection. I only need to set-up the wireless for a very small area and I will only be using my laptop around these 2 rooms. Now I understand there is lots of different routers, but I want something simple and relatively cheap.
Does the router need to be connected to a PC constantly or just when you are busy with the set-up?
What would your recommendations be???
