Do I go into my router to see them?I doubt that is your router perhaps it's interference of some some sorts or your DSLAM is faulty/overloaded.
Can you please post your line stats from your router.
This is what I get:Yes log into your ADSL modem/router, and go to the 'Status' page (name varies depending on router brand). You need to look for your line stats, like ADSL Sync Rate, Attenuation, Noise Margin, Attainable rate, etc..
Copy and paste them here, or take a screenshot, upload the image, and link to it from here.
I connect via ethernet and I'm with MWEB.1. Are you using the WLAN?
2. Who is your ISP?
My dad uses it.Why not disable your WLAN?
This is what I get: **snip**
