GPSJane
I am looking for a router with a torrent client and harddrive. It should also support wireless bridging and of course have ADSL.
Any suggestions?
Any suggestions?
Any suggestions?
Wow! Big demands!
Really not loving the idea of expensive/valuable electronics (hdd's) being so close to the wired PSTN
Wow! Big demands!
You sure you want of that intelligence and data sitting on lightning prone wired phone network?
Can't a small dsl router and net-top (EEE / Cape7) without the Windows tax, running an "easy" flavour of Linux work for you without breaking the bank and your electricity service provider?
Maybe even a DSl router and separate NAS that can do torrents?
GPSJane == CALAMITY Jane
Suprised she / he / they are not also asking for a built in GPS :twisted:
The "Lamborghini" of Routers -- OK OK give me TEN of those BWAH bwhahhhhhhh
Non-ADSL Routers:
Asus WL-500g Deluxe|Premium / Asus WL-500W / Linksys WRTSL54GS / TP-Link WR1043ND
DD-WRT + Torrent Client:
http://www.dd-wrt.com/wiki/index.php/Optware
Your best bet might be the TP-LINK WR1043ND, but I'm not 100% if it has 32MB RAM which would allow you to install all the necessary DD-WRT optional software to run the Torrent client. If you go for this, ensure that you buy it with DD-WRT preinstalled, which would be like R50 extra, but then you get to keep your warranty.
A friend of mine has the TP-Link WR1043ND and he installed DD-WRT and is now running a FTP server from it
I really doubt that you'll be able to get an ADSL router with a torrent client, but it's not impossible. Alternatively you could just use a laptop/EEE PC to run the torrent client.
Hahaha. She just wants what she wants. Is that so bad?
Dear Madam -- ONLY when it is unreasonable( at ALL other times "SHE" MUST be obeyed
I am not sure anyone makes the device you WANT -- at least not in a box off the shelf. ( that I know about )
There is a difference between bridging a wired LAN and a wireless LAN ( not all routers / AP's have a wireless bridging function )
More eggs ONE basket -- tidy -- but liable to disaster.
Unfortunately -- either way it IS going to cost you ........ ( the cost of getting your own way -- for men normally a Diamond :erm:)
DD-WRT can only be installed on some non-ADSL routers. There are also multiple builds of DD-WRT firmware, because not all routers have 32MB of flash which is required for the Mega build.
That Buffalo router is a real winner! You'll still need an ADSL router of course, but you might even be able to install the BitTorrent client on it like I've shown in my first post.
Getting a router with DD-WRT or RouterOS is definitely worth it!
Yotch did say that you can get it for R1.1k at Expansys/Bidorbuy. eg. http://www.expansys.co.za/buffalo-n...access-point-in-build-bittorrent-clie-190274/
I always prefer to have an ADSL modem as a separate device, so that you don't have to worry about replacing it when it gets struck by lightening![]()
