Routing Software PLEASE HELP
Volt4ge
hi to all
first of all thank you for reading and taking your time to see if you can help
i need Software to run on our servers.. that dictates which users uses which DSL line
EG managers uses 4mbps line
and employees uses 1mbps line
any sofware that can manage usergroups and which DNS/ line they connect through?
please any help is appreciated
What you need is a router. That can either be a router appliance that can handle dual wan links or a linux server running as a router. I dont know what OS your existing servers are running. If it is windows you could use ISA but my advise would be to use a good router or setup as linux box.
ISA, or a linux based derivative with a firewall set to do NAT to different external interfaces based on the source IP or network.
hi to all
RouterBoard Running Mikrotik OS and do policy based routing.
