Okty
- Aug 25, 2009
Hey guys
I had a borehole done awhile ago, however, the problem is, the water has a lot of fine 'dust' in it.
I assume it is from the drilling through the rocks that leeches into the water over time. It is quite noticeable, i.e. the water coming out has a 'silver/grey' appearance, you can smell the 'dust-smell' when hold the water at your nose etc. Sometimes I get a layer of water where it becomes clear, however, there might still be dissolved dust in it.
I am thinking of getting a sediment filter, since at the end of the day I would like to use the water for washing and bathing.
Any suggestions for sediment filters that won't cost an arm or a leg?
One promising filter I found was this one:
plumbitonline.co.za
Can filter as small as 1 micron.
Replacement cartridge also doesn't seem too expensive, however, don't know how long it will last before replacement:
plumbitonline.co.za
Thanks!
PlumbIt
PlumbIt
Thanks!
