Some help with Delphi and MySQL
acidrain
At a computer
Hi guys,
Ok, at the moment i have two sql database forms ( frmMember and frmBook ).
Now im following in the book on adding these two forms to a new project and the book says i must do the following:
Project | Add to project and select the unit ( which in this case is C15e02u ).
Now save the file with File | Save As..., save the unit as Memberu.
The same guide is for the book form.
Now I have done that as it states but on the next page, it says to go to Project | Options, where in the book shows (frmLibrary, frmMember and frmBook) under the "auto-create forms" list.
When i do that, however, all i see is frmLibrary and nothing else. Any ideas on what im doing wrong?
Thanks in advance
EDIT: Ok maybe this will help Screenshot.
Now what you can see, on the right is the project manager clearly showing the Memberu unit and Booku unit yet it doesnt show their forms ( like the project which, same area, you can see frmLibrary)
On the left is the Project | Options... where only frmLibrary is, but not frmMember and frmBook.
