somebody help me i need a graphics card
KYLEROX
i want the best graphics card for under R5000 somebody help me
Explain since u such an expert
Don't expect too much help from anyone with that kind of attitude. This isn't the mygaming forum where you are talking to your adolescent friends.
Anyway - try carbonite. Good luck getting someone to rate you though.
Since your buying something, your itrader rating doesn't matter much or at all.
Check the person you're buying froms' profile and look at their itrader score. Gives you an impression of how reliable they are.
if you need any carbonite info, don't hesitate to pm me. You can pick up great pre-owned hardware there, at great prices.
If you're looking for new stuff though, check out that gtx shop link. I'd recommend going with a new gpu. More mileage, less worries and a warranty in place.
Good luck with your search.
