There are smart switches available that don’t require neutrals. Search for Eachen switches. Work on the eWeLink app.Seems like you don't have a neutral there.
Live supply in red.
Live switched on the blue
Another live switched on the white
Looks like a two-way switch will be complex with a smart switch.Seems like you don't have a neutral there.
Live supply in red.
Um…there’s a difference between a two-gang switch and a two-way switch. I am talking about the latter.Nope. You install a capacitor on the lights. I have quite a few 2 gang smart switches without neutrals. I installed all of them myself and it wasn't difficult at all
Agreed - but if you don’t have experience in disabling a two-way switch, it’s not as straightforward as replacing a one-way switch with a smart switch…Oh I misread that. But you don't need a 2 way. Install a smart switch at the first location and a blank (no output load) switch at the other end then link it with software.
Edit: You can even get a wireless touch panel for the other end. Doesn't require any wiring. Just batteries every year or so
Because you already have the Sonoff, you'll have to pull a neutral down. It's possible to do yourself but not fun.Here’s the wiring diagram for the new switchView attachment 1421117
Or return it and get the Eachen if you can. And follow a wiring diagram to disable the two-way switch to be a one-way switch. Need to fix at both ends of the circuit.Because you already have the Sonoff, you'll have to pull a neutral down. It's possible to do yourself but not fun.
Yeah, this is an option too.Or return it and get the Eachen if you can. And follow a wiring diagram to disable the two-way switch to be a one-way switch. Need to fix at both ends of the circuit.
How does that work and where do you connect it on the actual light?Because you already have the Sonoff, you'll have to pull a neutral down. It's possible to do yourself but not fun.
You would need to identify at the light fitting which is live and which is neutral and then pull a neutral down to the switch. Far easier to buy one of the switches that doesn’t need a neutral…How does that work and where do you connect it on the actual light?
or pay an electrician to pull neutrals - did this when installing solar and didnt look back LOOV SONOFF switchesYou would need to identify at the light fitting which is live and which is neutral and then pull a neutral down to the switch. Far easier to buy one of the switches that doesn’t need a neutral…
I have a standard live in and a live out but no neutral. The specific light switches I got are the ones that go best with my look and feel so swiping them out isn't really an option. I'll have to add the neutral wiring. Connecting the neutral wiring on the switch is easy but not sure where it would go on the actual light.You would need to identify at the light fitting which is live and which is neutral and then pull a neutral down to the switch. Far easier to buy one of the switches that doesn’t need a neutral…
Neutral only runs to the switch, not to the light as well.How does that work and where do you connect it on the actual light?
Or put the switch in the roof where the neutral isI have a standard live in and a live out but no neutral. The specific light switches I got are the ones that go best with my look and feel so swiping them out isn't really an option. I'll have to add the neutral wiring. Connecting the neutral wiring on the switch is easy but not sure where it would go on the actual light.
The light will have a neutral wire to it already (else it wouldn't work). Neutral wires aren't always run to the switch box to save costs, mechanical light switches don't need the neutral.I have a standard live in and a live out but no neutral. The specific light switches I got are the ones that go best with my look and feel so swiping them out isn't really an option. I'll have to add the neutral wiring. Connecting the neutral wiring on the switch is easy but not sure where it would go on the actual light.
