Speed Camera locations for Nokia Maps
Capesharks
i have a N 96, with Nokia Maps running.. i recently went on a nice drive throught the country of close to 4000klm and while using the maps function, i was wondering if there is a application outthere for Maps to be updated and therefore pre-warned of all the normal speed trap places throughout the country or even region by region?:confused::confused::confused:
Good question. I would also like speed trap locations loaded onto my nokia maps.
If anyone knows how, please let us know. Meanwhile, I will google so long.
I do think its going to be difficult since don't think nokia maps supports warnings on passing a certain POI. An icon would have to suffice. I *think*
You may have to try Maps 3.0 for this. Apart from setting up a 'place' on a map, I don't think it is possible without extra software. Maybe another app will do it.
Was about to mention NM 3.0
Only problem is that it *may* not support his phone.
For what it's worth, Garmin beeps..
You sure it's not the cop car on your back bumper that's beeping?
HA HA !!
Um, don't think so....
:confused:
:o
It does an annoying whine when I enter an 80 zone.
And has little cameras on the side of the route. It beeps when I enter a region near those cameras.
Either that, or the battery gets low VERY quickly..
:D
