Kratos8051
- Nov 2, 2010
Hi guys,
I have an issue and I'm hoping you can help to give me some answers. My dad bought a third party decoder so that he can watch free-to-air channels without having to set them up constantly on the DSTV decoder (for some reason the DSTV decoder keeps deleting the settings for these channels). However, he only has a SD decoder (DSD 1101 if I remember correctly) and single LNB. Now, in order to get this free-to-air decoder to work, I need to "split" the LNB cable to both decoders. Initially I simply tried a splitter with DC pass on both channels to split the signal cable to two and to connect each to the decoders. However, I misunderstood the concept of DC pass, and as you can imagine, this didn't work. So I read up on how to split the cable and from all the guidelines, it seemed like I could simply connect RFout on the DSTV decoder to Signal In of the third party, but this didn't work. I tried numerous things, and in the end I just gave up and went back to the original setup of splitting the LNB into two using the splitter. The idea was to have a manual switch between the two cables. If my dad wants to watch DSTV, he just disconnects the cable to the free-to-air box and vice versa. However, like a miracle, this time it worked. Both decoders were receiving the signal fine. However, the free-to-air box loses the signal sometimes.
Now my questions: I know both decoders try to control the LNB. Is this the reason the free-to-air keeps losing the signal? Is there better way to split the signal into two for both decoders? The current setup is working, but I can't help to feel like it is a fluke.
