SQL Query - merging to data sets.
xrapidx
Ok, I'm having an off day at work, and can't figure this out. I need to join two tables, that have no key to join on.
TABLE A has a list of items, and their features. e.g.
ITEM_NAME, FEATURE_NAME, FEATURE_VALUE
Laptop1, RAM, 2GB
Laptop1, HDD, 160GB
Laptop1, Display, 14"
Laptop2, RAM, 1GB
Laptop2, Display, 11"
etc.
TABLE B is a list of features currently available, e.g.
FEATURE_NAME
RAM
HDD
Display
CPU
etc.
I need to join TABLE A to TABLE B so even if a feature (FEATURE_NAME) doesn't have a value (FEATURE_VALUE), it still gets outputed for each ITEM_NAME.
Anyone here know? Doing it in MSSQL....
Left outer join?
Edit: I would guess something like this:
select * from table_a left outer join table_b on table_a.feature_name = table_b.feature_name
Not sure if there would be any MSSQL specific issues though.
Re-reading your question though, I think I may have misunderstood your requirements...
It sounds like you are over-complicating the query?
Table A feature name is one from the list available from Table b.
You want all Feature name and value if any from Table A?
select FEATURE_NAME, FEATURE_VALUE from Table_A
If you want to find those feature_name from Table B that are not listed by any item currently in Table a:
select * from table_b where feature_name not in (select feature_name from table_a)
Hope this helps....
@@udiS3 : Neither of those will work. But thanks :)
I need to output a list that contains ALL features for an Item, even if they don't have a value set. TABLE A contains features for an item which are set, TABLE B contains a list f all features.
Ok so I think you want a right outer join then?
select * from table_a right outer join table_b on table_a.feature_name = table_b.feature_name
This seems like something that might be easier done in code rather than SQL though, or is that not an option?
I got it right eventually.
I created a tmp table by joining a distinct list of ITEM_NAME joined onto TABLE_B without using a join key, e.g. FULL OUTER JOIN ON 'x' = 'x'. Then joined that table back onto TABLE_A based on ITEM_NAME.
Out of interest - what code are you refering to? Application coding?
ne1 know of a decent tutorial site where i can read up on outer joins etc?
Im a basic sql user and often need to use the outer join cmds but cant understand the logic, or am just blinded for some reason.
Just an update - I had a decent drink at lunch - which brought my mind back into a decent state - what I was looking for was a CROSS JOIN.
Quick question.
With a left or right join... is it the LEFT or RIGHT table that is used, or is it which ever is LEFT or RIGHT of the equal sign?
e.g.
table_a
LEFT JOIN
table b
ON table_b.id = table_a.id
Which table retains all its records?
Quick question.
e.g.
table_a
LEFT JOIN
table b
table a
