Sn00zE
Hi guys..
I have a very weird problem and ran out of ideas on how to fix it..
I have a 384k adsl line, Mweb ISP. Connecting using a Vox router. Now here is the problem, I can only browse sites using IP's.. Can't use url names.. And this is on all the pc's, 3x laptops, 2x pc's. Ip's gets assigned by dhcp. If i add the mweb dns statically to all the pc's the internet works fine. Also if i dailup from the pc's the internet works fine as well. So yes so far it sounds like the router is at fault but here is the twist, I change the vox connection from mweb account to axxess account and everything works without any problems.
Mweb has reset my account, telkom has reset my line. Mweb checked on there side if my account was not restricted or anything and found nothing. Dns servers works fine according to them.
I haven't found or got someone to borrow me a adsl router to test with so im stuck there. Still looking.. Im getting frustrated now..
Any ideas for what else i can try?
