Strange E600 installation problems
Scafster
Hi Guys,
I wonder if you'll be able to help...
I have been using the Huawei E220 USB modem for some time and have had to revert back to my E600 card moden.
Prob I'm having is that once I uninstalled the E220 off my system I tried to install the E600 with no luck.
I am always been asked to locate the E220 usb driver during the install, obviously they are no longer on my system. I click ignore as many times as it will let me and obviously there is a prob with the E600 install.
I can't get the E600 to install because of this stupid error.
Can anyone pls help me with this frustrating problem.
Hi Guys,
Describe that part for me? Coz if its what i think it is, you need to point it to the system32 directory in Windows.
