Hi
I got a c2quad pc at home intel Q8200 with 4gb ram, G31 mobo, 9500gt512mb graphics card installed with xp (yes i know its old but its comfortable
i have a 4mb connection unshaped but for some reason my downloads are always slow, thought it was the line or isp at first but when i connect via wifi on the laptop i get line speed ....
my pc's lan port is blown so i'm using an add on card for the lan, could this the cause perhaps ?
i'm using utorrent and i've just reset it to the default settings which helped at first but back to slow again, i also have avast 5 free edition installed.
do you think any software could be causing my slow speeds ? or maybe its just the add on card ? i was thinking of a fresh install could that work or should i just install win7 and see if that helps ?
