Strange RDC issue
medicnick83
Paramedic
CBD, Cape Town
Hi guys,
Maybe someone can help because I can't seem to find a solution for this issue I'm having and I've done a ton of searching online.
OK!
So I try and connect to my home PC via RDC and it's all setup correctly because I can connect.
However!
On MY Laptop - I struggle to connect - I have to try connect multiple times before it connects - it connects, but disconnects with following error:
Your Remote Desktop Services session has ended.
The connection to the remote computer was lost, possibly due to network connectivity problems. Try connecting to the remote computer again. If the problem continues, contact your network administrator or technical support.
The thing is, I can connect from any one of 4 other laptops in the house and it works 1st time, no issues.
I have even created another account on this laptop and it also connects 1st time everytime with no issues.
Any ideas?
I have to connect a few times before it actually works and is just very irratating.
You could try using a completely different Remote desktop program such as TeamViewer which works very well especially over LAN.
Link
