We have been getting a lot of ADSL line drop outs.
Telkom's service has been very good in helping to try and trace the fault.
After much work by Telkom the problem remained and I decided to replace the router. No difference.
Here's the setup. The router is plugged into our 3Com switch which provides access to our users at work.
When the line drops, I cant even ping or access the router's IP address. It appears that some ADSL line fault is causing the router to reset. This has happened on both routers (Billion 7402R2 and the new Billion 7402G).
After a short period I can then access the router and watch as the connection is re-established.
Has anyone come across this before?
