JerryMungo
- Jul 18, 2008
Go to Safari downloads and resume it from there.Can I assume the second file below has stalled? How do I resume the download?
Use ctrl, cmd, 4 to copy it to the clipboard.Is there a quicker way to take a snapshot of a region on the screen and paste it into a document or a web page, etc?
Right now I'm seeing Ctrl-4 to select the region, then I click the image at the bottom right to bring up the options, then I tap (long or harder or whatever its called) the image to bring up a submenu, then I click copy.... then I go to the app and same long tap / hard tap or whatever and select paste.
I would prefer to have some way of defaulting to clipboard copy when I select a region and something like command+v to paste. Is there a quicker way?
You’ll have to resume it from that browser then.It was downloaded using another browser. Can I still see it in safari downloads?
I use Command-Shift 5 - brings up a host of options that you can pre-configure (eg save to disk, save to clipboard, etc) - can't remember if this is native or via Shottr which a great app that lives in your menu bar and allows you to configure many hotkeys for screenshotting purposes.Is there a quicker way to take a snapshot of a region on the screen and paste it into a document or a web page, etc?
Not Skype (didn’t know it’s used out there in the wild)Anyone else on Mac using Skype and having an intermittent weird issue of it hanging? It can be minimized, maximized and restored but it ignores any click or keyboard action when it's in the foreground.... it's done it four times to me today so far. New install.
So far what has blown me away is the audio quality on this machine. Incredible.
Use CMD + Shift + 4 to screenshot a section of the screen, or ....+ 3 to screenshot the whole screenIs there a quicker way to take a snapshot of a region on the screen and paste it into a document or a web page, etc?
There’s a windows laptop with the same performance and 24h battery life?Someone got a Mac for the same reason some get a nice big SUV.
Same performance, maybe, same battery life, not sure. I'd say no.There’s a windows laptop with the same performance and 24h battery life?
You got a M3 Macbook Pro with 16Gb RAM and 1Tb for R26k? Refurbished or imported?You'll have a hard time convincing me I could get something better for R26k
Big one too Willie, that I use all the time is CMD + space bar. Calls up spotlight search. Really helps with workflow.Not really, that one was easy - cmd+shift+5 and you have the whole snipping tool available with options to set defaults for saving output (clipboard, file, email, etc). Getting used to the new keystrokes is mostly all I have to do for now.
Ur welcome! Enjoy the mac - once you go mac you never go back.Thanks, I came across spotlight search once yesterday and thought… now that I could use!
