I have fibre (Vuma/ Axxess, 50/5) but am getting very slow speeds and the connection drops when I'm in my office which is a bit further away from the wifi router. I have an old DLink wifi router. I bought a TP Link C60 to replace it, and I can't get it to work. When I take out the ethernet cable from the Dlink and plug into the TP Link, the internet light on the TP Link remains red. I've checked all the settings (it's DHCP), and it picks up an IP address, but no connection. Plug the same ethernet to the Dlink and all works great. The TP-links works if I plug it into the Dlink as an 'extra' modem (internet light goes green and I can connect), but then suffers the same slow speeds as the Dlink.
Hours on hold with Axxess have not resulted in any advice other than 'reset the router' and turn it all off and on again. Anyone have ideas why the TP link won't connect to the internet via the fibre modem, but will connect via the Dlink? I had this problem when I swopped out routers before and Axxess at that time did something on their end and it all worked. But can't get any useful help from their tech support this time.
