tedelex IntelliPower - Intelligent Uninterruptible Power Solution System
rpm
Admin
Staff member
Johannesburg
Posted by: altaaf
Description: tedelex IntelliPower - intel 4 Intelligent Uninterruptible Power Solution System FEATURES new in box with 12 month warranty * Uses deep cycle 12 volt batteries * Built - in Automated battery charger * Seamless and automatic switchover to batterybackup on loss of power * Provides overload protection * Seamless and automatic switch back to mains on restoral of power * Cold start operation * LED indicators with audible buzzers for status changes and alarm notification * User installable * simplified step -by-step user manual * Battery cables supplied * Continuous back up power of 8 hours CAPACITY VA / W 2000VA / 1200W AC INPUT Nominal Voltage / Nominal Frequency 220/230/240VAC / 50Hz or 60Hz (Auto Detection) Voltage Range Selector – Narrow / Wide 170~280VAC / 90~280VAC OUTPUT Voltage / Output Wave Form 230VAC +10/-18% / Modified Sine Wave Frequency / Efficiency AC to AC - DC to AC 50Hz/60Hz +/- 0.5Hz / >95% - >80% BATTERY / CHARGER Nominal Voltage / Charging Voltage / Charging Current 24V DC / 27.4V +/- 0.4V / 10Amp maximum Overcharge Protection 32V +/- 0.8V Charger stops and Fault Alarm Sounds TRANSFER TIME Typical AC to DC or DC to AC Typical 15-20ms – 40ms maximum INDICATORS AC (Mains) Mode (fully charged) / DC (Battery) Mode Green LED Lit / Yellow LED Lit AC (Mains) with DC (Battery) Charging Mode Green LED Flashing every 2 Seconds Overload – Fault Red LED Flashing every 0.5 Second / Red LED Lit AUDIBLE ALARM Low Battery Voltage in Battery Mode Alarm sound beeps every 2 Seconds Overload / Fault Alarm sound beeps every 0.5 Seconds / Alarm Sound Continuously PROTECTION FEATURES Built-in Protection Features Deep Discharge, Overcharge, Short Circuit, Overload Battery Short, Over Voltage, Under Voltage PHYSICAL Dimension (D x W x H) mm / Net Weight (Kgs) 249mm x 242mm x 80mm / 2.5Kg ENVIRONMENT Operating Environment / Noise Level 0-40C Temperature 0-90% Relative Humidity (Non-Condensing) / Less than 45dBhttp://www.amapholdings.co.za/intellipower/intellipower.html 072378460
Price: R7000.00
