Telkom Lte data usage check
Obieone
capetown
Does anyone know how I can check my data usage ? Google has not been helpful and the chat consultant basically ignored my request and e-mailed me the usage instead I would however like to be able to do this myself instead of going through the rigmarole of chatting to an agent every time.
@chromedome
You have to register on the My Telkom portal and then simply link the sim to your account (will send OTP to sim number so check in router).
You can view the current SIM usage without registering there as well if you're browsing from a Telkom SIM.
You can then monitor from there or from the Telkom app on phone.
Thanks a lot netstrider, much appreciated.
@chromedome
