Telkom has recently changed their roaming partner from MTN to Vodacom.
Previously when roaming in areas without Telkom networks, the switch over was almost seamless and i most often got a 3G speed.
Since Telkom moved to Vodacom, it does switch over but the data speeds are almost always E (Edge). In most cases, I cannot even perform simple browsing with this speed let alone more hungry data services. Has anyone else had the same experience? If resolved, please post your resolution.
I have never got 3G or 4G from Vodacom while roaming.
