Thermal Paste and Water Cooling
I have an i5 that is running the standard cooling unit. I ordered an h100i to replace it with. I am assuming that I have to remove the thermal paste of the cpu. So I did a bit of research and I got this video on Youtube.
https://www.youtube.com/watch?v=x9MJUuU58vE
Must I remove the thermal paste as in the video with Isopropy Alcohol or is there a better way? Where can I get this Isopropy Alcohol? Will Surgical spirits work?
Thanks in advance.
Possibly a stupid comment, but I just struggled with this myself installing an Antec Kuhler 620 on an Asus P8Z68V mobo.
If you install a closed loop water cooling system, with no fan speed feedback, the board will beep and complain, and wait for you to press a key to confirm. Unfortunately, my display was connected via DVI, and for some bizarro reason, it was not showing the POST. I ended up stripping and rebuilding the PC for no reason, only to have the same beeps (1 long, 4 short). I eventually tried connecting my display to the VGA port rather than DVI, and saw the POST, and the error message. A quick trip into the BIOS, disabling fan speed monitoring, and I was back in business, even with the POST showing up on the DVI interface.
Unfortunately, I lost a day trying to figure out what the problem was, before stumbling onto the VGA solution :-(
And to answer the original question, I used surgical spirits to clean the previous thermal paste off the CPU.
At Dis-Chem just ask for rubbing alcohol. This is isopropyl alcohol.
Personally never used anything more than some toilet paper to wipe off the old TIM. If I'm feeling keen I'll take an earbud and try get it a little more clean
Surgical Spirits usually contains castor oil and other antiseptic ingredients which is not a good idea near sensitive electronic components. Rather get isopropyl alcohol from Dischem as mentioned above - usually you can ask them to pour out 30ml (<R10) but you may need to show your ID book and sign for it.
http://forums.overclockers.co.uk/showthread.php?t=18032509
Or you might want to not only totally remove the old material, but also prepare the surface optimally for the new application of TIM, by using Artic Silver ArtiClean. (http://titan-ice.co.za/arctic-silver-arcticlean-kit.html)
This is a 2 stage application that 1st remove the old TIM and 2nd do the surface prep for the next application.
Get some snake oil while you're at it, I hear it reduces your temps by 0.000001 degree, at only $100 per ml it's a bargain.
Seriously, just wipe clean the surface with toilet paper and alcohol or meths and you'll be good to go.
