Thermocouple connection
Snyper564
Gauteng
Hi All,
Busy building a brew kettle and want to attach this to an URN
Where can I source the connection to do it neatly?
Dont wanna just dangle it in the liquid, it works but its not as pretty
Hi All,
PTFE washers (or at a push copper washers) and stainless steel nuts will do it.
You may want some SS washers as well for added strength.
Ohh thank! I guess no need to over complicate it drill hole connect washers and nut and bobs your uncle?
100%
PTFE is soft enough to waterproof and will even be allowed if you do get the still, erm "brew kettle" registered with SARS as alcohol will have no effect on it.
SS cause anything else will rust.
100%
its an urn for beer :)
No distillation
I am surprised they use those terminals... K-type is supposed to have a specific connector which serves as a junction which is compensated for in the amplifier.
Thats banggood for you
Nah, you just move the junction to where the connector meets the wire. The only effect is that you can't measure the temperature at the junction (at the connectors), so you lose accuracy. Most people use devices that are so poorly compensated, it does not really matter anyway. For an application like this a PT100 makes a lot more sense.
I did work with these things years ago... the ref junction (aka cold junction), had to be near that chip and the connector had to be near the chip. We were taught NOT to use electrical terminals like that, which is why, you will notice multimeters so equipped have the right style connector.
Also, using this type of measuring device for this application is overkill. PT100 would be better. A cheaper still option would be one of those solid-state thermometer ICs too.
Hi All,
https://www.rs-online.id/p/thermocouple-k-with-head-6-x-200mm/6212401/ you should have gotten a holder. they work on compression fittings. we used to drill out 6mm Copper tubing compression and Ferrules to mount them in . Neat and Profesional .
Yes, You do not use crimp on terminals. or normal wire for that fact. you use the Supplied Braded wire and fasten the bare wire directly into the reader.
Hi All,
Looks suspiciously like Automation....
Sorry not following? Totally out of my depths at the moment
you can use the Thermocouple to record and set tempratures automatically with arduino. add an element/chiller and you can regulate it.
Correct using it with the PID to regulate the element to ensure needed temp is maintained.
You are getting Serious with your Beer.
My goal with brewing is to brew a beer I would be happy to pay R30-R50 a bottle. Basically every beer is craft beer level thats what I aim to make. I "chase the craft". Every element you control means a better end result. Temp is super important. At present I use an STC1000 but its 2deg fluctuations acceptable but it can be better. Hence the upgrade to PID. One massive skill I learnt and have been developing since hard lockdown
Some beer I made
Belgium Triple
Imperial pastry porter
Hazy IPA
Mexican Lager
Dunkelweiss
Cream ale
English special bitter
Hi All,
When I setup my system I replaced the K thermocouple with the one below so that I could standardize on one size. Also based on what I researched when I built my system they said this specific K thermocouple didn't last nor was very accurate.
Connect with normal 1/2" BSP barrel connector.
Also just FYI. once everything is setup and running that 1m cable is really short.
Mmm that seems like it might be the better option where did you get the barrel connector?
Also are you using the same PID? Just connect two of the cables?
Could this work?
