TP-LINK TD8840 help please
ahf
Down Under
Hi All
Bought TP-Link TD-8840 router today, it works but it don't open all webpages including MyBB:confused:
Any assistance would be appreciated.
Currently using Planet ADE-4400
Thanks in advance.
Using this at home. Cheap and cheerful, no issues.
Perhaps try a factory reset ALSO check the DNS servers you are using on the router...?
Are you using any other software like peerblock which can be set to block http traffic?
J
Hi All
Thanks in advance.
J
@jsheed_sa....OK I've used the quick setup and no I don't use peerblock
Will have a look at the DNS servers and if that fails reset the router
Thanks!
UPDATE:
All sorted out, thanks jsheed_sa!
Sold my TP-LINK TD8840 to my friend and he reports that this router only allows two PC's to be connected and not four. The router is still under warranty so I can take it back however it would be appreciated if someone can assist my with the settings if any to get four PC's connected.
Thanks in advance.
