Tritton Pro+ 5.1 Volume Controls Mixed Up
bromster
CT
I hope that there are some Techs on here that are smarter than me. This has perplexed me because I haven't used this headset on my PC in months. As far as I can tell, the only thing that has changed since then is my installing Windows 10.
Whatever generic driver windows uses seems to have installed correctly and the device shows up correctly.
1) My volume control on the box no longer works.
2) The system volume is now controlled by the inline voice adjustment volume rocker.
3) The mute / individual channel volume control seems to be working on the controller itself, but it doesn't do anything to the system volume. This rocker switch should control the volume, but now it doesn't.
I also don't see any support on the madkatz website. Help! :D
