Two port "mini" switich/hub
xrapidx
Anyone seen a cheap two port mini switch or hub locally?
I have a single ethernet cable behind my TV, which connects to a Pi - I'd like to add a Chromecast Ultra - both will obviously not be used at the same time.
1.) I cannot run another Ethernet cable.
2.) I'd ideally like something small
3.) Not wifi.
4.) TV is wall mounted, so space is limited.
I bought something off aliexpress, and after three months wait, discovered I badly read the description - its manual.
Those are also what I've found, problem is fitting them behind a TV.
See an eBay is a two piece adapter that takes two cables to one and then the reverse on the other side... Just dont want a wait again.
Doesn't seem to work :(
Pi and Chromecast plugged in one one end, the other end goes into a switch... the switch activety lights come on - but neither device is available on the network.
Did you put it on BOTH ends? 2-ports used Router side and 2-ports device side with one cable in the middle?
You will also have to force devices down to 100-Mbit.
Yip... and both ports light up on the router.
Further thought on this. Switching them around won't make a difference...
