MiffMeister
I recently changed from a Mikrotik setup to a Unifi setup. Mainly because I like the Ubiquiti kit and the awesome stats from the controller.
My town house is your standard with bedrooms upstairs and lounge, kitchen and garage at the bottom. Roughly 140 square metres.
So I got a USG, Poe switch , cloud key and 2 x AC Lites. The AP's are ceiling mounted, 1 on each floor. What are people's dBm strength on their clients ? On 5ghz if I'm in the same room it's anywhere from -50 to -60 (depending on how close to the AP you are) and then through a wall it will be -65 to -80. If I run a bandwidth test I get decent speed using the Unifi app on my phone. Is this the general stats for the AC Lite, or would I get better results from an AC LR? .
