Under-desk cable management trays
Barbarian Conan
Joburg
What do you use for under-desk cable management?
I bought two of these to use as cable management trays, but they don't quite work. The proper stuff I see for sale at RS components are quite expensive and you need to buy quite a few at a time.
Just using cable ties and cable tie loops also don't work as well as I would like.
Google is your friend..there are a number of companies that sell what you are looking for.
Yeah the options seem really limited. Finding a “modular” multi plug was like finding a needle in a haystack - by modular I mean one with a disconnectable power cable so that the multi plug itself could be mounted to the desk.
What I ended up doing, which left me somewhat satisfied, was to screw my multi plug into the wall as high as possible under my desk.
By just not having a multi plug on the floor cleaned up my under table mess a ton.
Check out Gelmar.
They have ton of kitchen fittings that could be repurposed for cable management.
I got those under desk baskets from them, but they are too wide. I couldn't see anything else that seemed useful and decently priced in store. I'll check online.
