Budza
I need an uninterruptible power supply. Convinced not having one is what caused my mobo to die on me
This thing: http://www.apc.com/resource/include/techspec_index.cfm?base_sku=BK350EI
has 3 outputs, max 350VA, 210W. Is the 210W limit for battery output only or for the device as a whole? If battery only, is there no limit on what it can put out while on AC?
Now, does this mean I can run 3 PCs off it? IE, an HP Microserver, HTPC and a gaming PC?
Microserver will be on 24x7. HTPC a few hours each evening, gaming on weekends. Unlikely all 3 will be on at the same time for very long, so best case is only Microserver needs to draw on battery, possibly that plus either of the other two but unlikely all three at once...
The UPS will smooth out power to all attached devices and hopefully allow auto shutdown of the Microserver when left unattended.
Hoping I don't need something like this for these PCs: http://www.apc.com/resource/include/techspec_index.cfm?base_sku=BR900GI
What'd you use? TIA.
APC Back-UPS, 210 Watts / 350 VA, Input 230V / Output 230V , Interface Port USB
