UPS and Battery
Rizzler
Can anyone tell me if I have a UPS as in this photo will I be able to pit the bigger battery in?SNAG-000328.jpgSNAG-000327.jpg
It won't fit, but it will work (external fitment). Just keep in mind that the charging circuit in that UPS was not designed for a 40AH battery.
You might have to open up your UPS to see if it has 1 (12V) or 2 (24V) batteries though.
Edit: As per the specs I see 1 x 12V.
Most UPS's under 1000VA are 12v and use 1 battery.
Both my APC UPS's at home have huge external batteries that I fitted years ago.
They run like a dream
Just bare in mind the charging circuit will run hot as it runs for a long time replenishing juice back into your battery.
I have had no issues with APC myself.
lol that looks like such a fire hazard waiting to happen :)
My thoughts too :X3:
LOL No fire yet, luckily my APC inverters stay cool when recharging the battery after load shedding.
I modded a no brand name one like this years ago and it gets bloody hot. Hasnt blown up yet (that I am aware of, in my exes lounge)
You're freaking me out with the red cable running from the negative pole into your UPS.......:X3:
Hi Chuckmyster! This is awesome!
Could I ask some Qs?
1. How many watts can you pull and for how long? I'm looking to power 2 POS machines and a server pc for 2-3 hours aka loadshedding.
2. Which APC model do you have?
3. Did you remove the internal battery or are the cables connected to it?
Thanks a million!!
Do you want to extend backup time? Takealot:
Note:
A UPS is not designed to provide continuous power, merely a window period that allows a computer or other user to finalise the work at hand and shut down.
RCT may use 24V (2x 12V 7AH batteries in series) so just check that out too.
Lol. This photo should win the photo of the year and also automatically come up everytime a UPS or Inverter thread is started. :p
