andre1809
- Aug 14, 2023
Good day and a happy new year to you.
- I have this 1000VA UPS that houses 2 x 7AH 12VDC lead acid batteries connected in series. Can I replace these with 2 x 12AH 12VDC batteries?
- If the 12ah batteries are a little larger (like my garage door motor backup battery), I can modify the enclusure to fit them, or, I can put them in a housing outside the UPS and extend the leads if necessary.
- I suppose that charging time will probably also increase, which shouldn't be a problem.
- My main question is: Will it work?
