USB Charging stations
Crusader
This side of Hell
I'm looking to simplify things and looking for something I can use to replace all the various chargers for phone/tablets etc. and get something cable of charging more than one device at a time. I don't really need something extremely fancy with PD or the like. I just want something that's from a reputable brand, reliable and good quality.
Something like the Huntkey 4 Port USB charger ( https://www.takealot.com/huntkey-4-port-usb-1-type-c-charger/PLID55543494 ) looks like it might fit the bill.
Any suggestions?
Need to charge some power banks, android tablet, iPad, baby monitors etc. Don't need more then two slots to be honest.
I would never charge my expensive electronic devices from a cheap/"no name" charger, the risk might be small, but it's not worth it.
If you're on a budget and charging speed etc don't matter:
Bumping this thread.
Have a similar request, had a charger which I bought a long time ago from takelot which shorted out, almost fried the two devices connected to it.
Any issues with the below or any other recommendations?
https://www.checkers.co.za/All-Depa...Talk-Dual-USB-3-Pin-Plug-Charger/p/10614936EA I use the normal one and it works fine. I guess this will too.
Thanks for this.
I hear you on expensive devices and sub par equipment, Anker is a decent brand, so appreciate this link - i didnt seen any other decent well know brands at an affordable price, so this is much appreciated.
Thanks for this.
McDodo and Unitek. I also use these. The more expensive chargers are GaN and are smaller and have higher power output, up to 140W. Anker also make these but not available in SA, can get on Amazon. Ugreen is another good brand. I use a 120W McDodo with an iPad Pro M2 and Asus ROG Ally.
Just to add, the newer GaN Prime Anker products have Infineon Technologies (Germany) controllers while the McDodos (except the 140w which also uses Infineon) use Power Integrations (California) controllers, FWIW.
