USB flash disk not being Read by PC
Peder
Hobbit
Pretoria South Africa
Hi Guys
I am having a problem...
Any usb disk or anything USB i put into this one computer will not open. When i go into device Manager and Click on the USB device it says "drivers for this device are not installed(code 28)"
When i click uninstall and Then Update Drivers it says "One of the Filter Drivers installed for this drive is invalid"
Can anyone help?
Thanx in advance
Peder
USB Drive has failed... It may be possible to recover some of the content, but code 28 error on the USB device is indicative of a failed device. The USB ports on the system may also have failed?
The USB device is reading fine on another PC, its whenever i put anything USB in it doesn't work...
There are 4 onboard USB and 4 PCI usb Ports. and they all give the same problem...
What driver do i search for?
Either it's a hardware problem on the USB port or the generic Winodws USB driver is corrupt. Try Uninstalling and re-installing the all the USB devices under Device Manager
Edit: There is a driver for the USB port and another driver for the USB device. The USB port driver seems corrupt.
where do i get this driver?
I did uninstall and reinstall drivers for the ports...
Weird, I've recently picked up the same problem... yet my usb mouse works fine.
true... And its not my own computer although only i use it. Its just i need to get sound tracks off of it and then i have to bring it home every sunday so i can get the sound off...
Its frustrating...
Anyone got an idea?
What OS is this machine running?
Doesn't XP have a 'patch' for USB problems like this one mentioned?
(It's fixed in SP3 as far as I know)
I remember a friend having this problem - I gave him SP3 and he didn't have the problem again.
Uninstall and replace the Host Controller and Bus controller drivers ( ALL OF THEM ) with the generic windows variant instead of the motherboard manufacturer to get rid of this type of driver corruption issue in the rare case a normal driver reload does not solve it
Get the motherboard CD/DVD as it normally has the 'correct' drivers for everything on there.
I use those first and move on from there!
It's why they are there eh!
Its XP
I put SP3 on the PC but its doing the same...
I'll try that again... Look for Drivers
The wiring of the usb front panels might be done by a noob IT technician... do not trust those...
Plug the stick into the back of the panel and see what it does
You don't need USB drivers for Windows XP SP2+
Had this prob the other day. Saved this from the ms site. Havn't got the url, sorry.
A computer that is running Windows XP cannot detect a USB thumb drive, an Apple iPod, or an external hard disk drive
View products that this article applies to.
Expand all | Collapse all
SYMPTOMS
You attach a USB-based device to a computer that is running Windows XP. Then, you try to scan for hardware devices. However, the computer may not detect the attached device, and you may not see
the device in the My Computer folder.
You may experience this problem when you are using one or more of the following devices:
* USB thumb drive
* Apple iPod
* External hard disk drive
Additionally, you may not see the iPod in the iTunes application.
Back to the top
CAUSE
This problem may occur if there are corrupted or incorrect keys in the registry....
Note There may be other reasons that a USB device is not detected. For related Microsoft Knowledge Base articles, see the "Similar problems and solutions" section.
Back to the top
RESOLUTION
Important This section, method, or task contains steps that tell you how to modi...
Important This section, method, or task contains steps that tell you how to modify the registry. However, serious problems might occur if you modify the registry incorrectly. Therefore, make sure that
you follow these steps carefully. For added protection, back up the registry before you modify it. Then, you can restore the registry if a problem occurs. For more information about how to back up and
restore the registry, click the following article number to view the article in the Microsoft Knowledge Base:
322756 (http://support.microsoft.com/kb/322756/ ) How to back up and restore the registry in Windows
To resolve this problem, delete the UpperFilters registry value and the LowerFilters registry value. These values may cause access problems. To do this, follow these steps:
1. Click Start, click Run, type regedit , and then click OK.
2. Locate and then click the UpperFilters registry value. This value is located in the following registry subkey:
HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Control\Class\{4D36E980-E325-11CE-BFC1-08002BE10318}
3. On the Edit menu, click Delete, and then click OK.
Note If you receive an error when you try to delete the registry subkey, you may not have correct permissions to edit the subkey. For more information about how to set or to change registry
editing permissions, click the following article number to view the article in the Microsoft Knowledge Base:
310426 (http://support.microsoft.com/kb/310426/ ) How to set or change registry editing permissions in Windows XP or in Windows Server 2003
4. Locate and then click the LowerFilters registry value. This value is located in the following registry subkey:
HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Control\Class\{4D36E967-E325-11CE-BFC1-08002BE10318}
5. On the Edit menu, click Delete, and then click OK.
6. Exit Registry Editor.
7. Restart the computer.
Note If you remove both registry values and you lose functionality in a particular program such as CD recording software, you may have to reinstall that software. If this problem occurs again, contact
the software vendor for help.
For information about how to contact Apple Computer, Inc., click the appropriate article number in the following list to view the article in the Microsoft Knowledge Base:
65416 (http://support.microsoft.com/kb/65416/ ) Hardware and software vendor contact information, A-K
60781 (http://support.microsoft.com/kb/60781/ ) Hardware and software vendor contact information, L-P
