Using MTN-supplied Huawei E160 with Vodacom?
frankvw
Hi, everyone,
Since the area I live in has been abandoned by Telkom (lines have been out of service for months and Telkom employees have told me and my neighbours that they will not be fixed!) I am reduced to using wireless. I am a web developer working from home so Internet access is not optional to me.
I have a Huawei E160 supplied by MTN. Their network performance has gone from worse to terrible - although the towers supply strong signals, throughput is close to zero (and not just at my house - I have had the same experience in many parts in the south of the Jo'burg area) which leads me to conclude that their network is in bad shape.
I have borrowed a Vodacom-supplied E220 from a friend, which I am now using to write this post. (I tried it with MTN, but did not manage.) However the Vodacom SIM from the E220 won't work in my MTN-supplied E160, nor will my MTN SIM work in the Vodacom E220.
Does this mean that these modems are network-locked and/or SIM locked? Elsewhere in these forums I have read about MTN using oddball SIMs in the E220 and Huawei supplying them with customized modems, but I am not at all sure that that applies in my case.
I would assume that Huawei makes standard hardware that then gets flashed with provider-specific firmware. So I am sure that this should be fixable somehow. But how?
I really want (no, need) to get rid of MTN and switch to Vodacom - MTN's performance of late has been useless, and in practice their wireless internet access is unusable to me. But I'd hate to fork out money for a new modem. I had to buy the MTN modem since I immigrated into South Africa several years ago, and I don't have an SA ID book yet, so I could not get a contract anywhere - the best I could get was a prepaid deal with MTN where I paid cash for the modem (which I therefore now own) and I don't want to have to fork out a similar amount for a similarly expensive modem again, simply for the privilege of sticking a Vodacom SIM card into it.
So how can I get my MTN supplied E160 to work with Vodacom SIMs and use Vodacom 3G instead of the horrors of MTN?
All suggestions would be appreciated!!
// FvW
download the e160 firmware from the huawei website and flash your data card, then you can use any sim in it.
I think you mean dashboard, not firmware.
Before I stuff up my E160 - is it the firmware or the dashboard, and what is the difference? (I presume that the dashboard is the application that lets you connect to the network, but I am not entirely sure).
Thanks for the replies anyway, guys - it's much appreciated.
// FvW
The firmware is the software that is executed by the CPU on the modem.
The dashboard is the software that gets installed on your PC.
What gets everyone confused is that the dashboard installer also gets flashed onto the modem.
The firmware is the software that is executed by the CPU on the modem. The dashboard is the software that gets installed on your PC. What gets everyone confused is that the dashboard installer also gets flashed onto the modem.
I see. So I don´t need to update the firmware?
I've been through the Huawei website and I have found a firmware upgrade for the E160G (which I have) but it's a .bin file and there doesn't seem to be an installer for it. I cannot find the dashboard software anywhere. :confused:
Could you give me a hint as to where to find it?
Thanks for the info so far!
// FvW
You need not do either!
Just set up a new Profile for the E160 from the dashboard program.
Static APN of internet and dial string of *99# should do it!
The E160 is not network locked but some E160 are locked against firmware upgrade! This is done to effectively to stop you de-branding the modem. I've not tried a MTN E160 but I had a O2 UK modem and that needed a code to enable firmware upgrade. You don't need to change the firmware so this shouldn't be a worry!!
You can however upload a new dash board to the E160G you can get that here: http://www.dc-unlocker.com/downloads/open/33
I'm going to give that a try right away!
That would be great. I am a bit concerned about reflashing my modem with firmware from other sources than MTN, because if I flash the wrong firmware version or otherwise botch it, my modem will be out of commission, MTN will be unwilling to bail me out, and I will be left without the Internet access with which I earn a living.
I have an E160G (which I should have mentioned in my original post but overlooked) but one would expect that to make little difference in this regard.
I will keep that link, but use it as a last resort.
Thanks a lot, Jim! I'll let you know how it works out.
// FvW
Good news!
The E160 and E160G are almost the same, the non-G version (i.e. the E160) also supports 3G/HSDPA on 850MHz and 1900MHz which is of not interest unless you are off to the USA or South America! The E160G works on 2100MHz only which is fine for Africa & Europe etc.
HI I bought a E160G from borbuy but nothing happens when i plug it in, can it be its not compatible with my pc? Or any help how to fix it?
