MyWorld
I have an Acer data projector and bought myself 10m and 5m of VGA cable (same brand, for the life of me I can't remember who) to connect it on the PC for presentations. The projector only has VGA, S-video, Composite and USB ports.
The problem is the cable only allows 640x480 display resolution, and I know it is the cable since I tried it (the 5 and 10m cables) on a VGA LCD and the same results, 640x480.
Is there then a certain brand that one should get? What should I ask for to get the "right" cable that will allow for full resolution?
The VGA cable that came with the LCD monitor works perfectly and displays all the resolutions of the monitor and the projector, so I'm 100% sure it is the VGA cable that is messed up.
