Vodacom 3G Speed Tests: Your Help Needed
rpm
Admin
Staff member
Johannesburg
Hi folks
AS part of this year’s broadband survey we need a few tests using the “Line Speed Meter” It will be great if you can install the Line Speed Meter, run a few tests and post your results URL.
http://www.tcpiq.com/tcpIQ/LineSpeed/Download/
The more tests the better, but even if you can just run one or two tests it will help tremendously.
Just for good measure we will throw in two MP3 players for two lucky testers :D
Regards,
RPM
I'm getting minus results! Something's off!
I know my throughput speed is up to maggots in the evenings, but this is ridiculous.
Any ideas as to what is going wrong?
TCP/IQ Linespeed test. Doringkloof Centurion
My Results 1st one.
http://www.tcpiq.com/tcpIQ/LineSpee...rHistory24HrSpeed&CountryId=196&UserId=244830
Code:
 Last 24 hours  Last 7 days
Number of tests  1  1
Download speed  286.56 KBits/sec
35.82 KBytes/sec  286.56 KBits/sec
35.82 KBytes/sec
Upload speed  300.71 KBits/sec
37.59 KBytes/sec  300.71 KBits/sec
37.59 KBytes/sec
DNS Speed  0.00 mSec  0.00 mSec
Latency  0.00 mSec  0.00 mSec
:cool:
Hey @rpm. How long do you want us to run this for? I have been firing it up in the evenings because at work I use a different connection. So I am happy to do so until you take final stock of the readings.
tcpIQ Speed Test
@rpm. I dont like what I see it is demoralizing. DL lower than UL :confused:
@v3g. Your comments. Is this for real? So who do we believe speedtest/speednet /tcpIQ??
Latency Zero 0 :confused:
@rpm IMO I don't think this is a good test to use for getting an overall view of 3G speeds. It is a waist of almost 1MB & costly, if used on useless results.:p
Number of tests 2 2
Download speed 293.77 KBits/sec 293.77 KBits/sec
36.72 KBytes/sec 36.72 KBytes/sec
Upload speed 328.14 KBits/sec
41.02 KBytes/sec 328.14 KBits/sec
41.02 KBytes/sec
DNS Speed 1658.00 mSec 1658.00 mSec
:cool:
Hi Codemaster
Thanks a bunch for the help! WE will compile the results on Saturday, so no need to continue testing after than.
Regards,
RPM
Options tcpIQ
@rpm
@v3g
Which option 3G do we select during setup of the test
3G (Dialup over W-CDMA)
3G W-CDMA (Includes Next-G)
Wireless Proprietary
I have used option 1 is that correct ???
:cool:
Not much time, I will do as many tests as possible until then.
It's just a pity that my connection is ACTUALLY working today, would have liked to see the results of my connection from the past 2 weeks :mad:
Option 2, then the speed is 1800/384 (but I don't think it will matter if you selected option 1, as long as you selected the correct speed)
@rpm
@v3g
:cool:
I'm uninstalling. For whatever reason, this thing isn't working for me. I've checked firewall settings, rechecked all the installation settings. Tested over Telkom ISP ADSL as well. Something is blocking it and I can't figure out what it is.
Ignore my results, it just ain't working.
Number of tests 5 21
Download speed 358.33 KBits/sec
44.79 KBytes/sec 318.53 KBits/sec
39.82 KBytes/sec
Upload speed 255.61 KBits/sec
31.95 KBytes/sec 205.99 KBits/sec
25.75 KBytes/sec
DNS Speed 707.00 mSec 1052.00 mSec
From 2 locations:
Opp Wanderers Stadium in Corlett Drive, office hours
From Randjesfontein, Halfway House, line of sight to Voldemortworld, evenings
Number of tests 1 1
Download speed 386.85 KBits/sec 386.85 KBits/sec
48.36 KBytes/sec 48.36 KBytes/sec
Upload speed 321.83 KBits/sec 321.83 KBits/sec
40.23 KBytes/sec 40.23 KBytes/sec
Test done using Option Globetrotter 3G+ Data Card. Will do another later using my E220.
