damian24
So I'm trying to find an Android phone that replicates the following functionality on my iPhone -
I have my UK o2 sim as an eSim and a Vodacom physical sim in my iPhone, the Vodacom sim is voWifi and roaming enabled - the Vodacom sim is forced to roam on an unsupported mobile network for roaming (so that I don't get charged roaming fees).
This works great when I'm on WiFi as I use my Vodacom sim as a normal line without roaming fees. Now for the cool bit... when I disconnect from WiFi, the iPhone switches to using to o2 esim for data and Vodacom is reconnected (with voWifi using LTE). I still receive and make calls as if I'm in South Africa without roaming when I'm out and about..
on the iPhone when I look at networks, it shows my o2 signal strength and Vodacom (but says Vodacom is using mobile data for calls)
I have not heard of or seen any Android phones with this feature and was wondering if there are any that do the following :-
1) Offer voWifi at the same time for 2 operators from different countries
2) Support the Voice over mobile data feature (ala iPhone's as above)
Ta
D
Ta
D
