Kull Warrior
- May 22, 2012
Hi guys,
I've recently started using Surfshark VPN and I have been testing regularly it by asking Google " where am I / What's my location?".
Initially it gives the correct answer depending what location I have set the VPN, ie. Spain, USA etc.
I noticed though after leaving it running for a while and ask the question again, it will give the correct answer to "whats my location? as being KZN, where I'm from.
When i check the ip address in Surfshark it still says USA or whatever and i see that it been connected for hours and I didn't lose the connection. Then when i go to other sites it shows the location that's stated in Surfshark.
So my only issue is Google knowing my location even when Surfshark is on. I'm worried that ISP's will know my location.
What can i do ?
Thanks, guys
What can i do ?
Thanks, guys
