Wall mount for LG 47LV3530
Freakboy
Centurion
Hey guys,
I'm in search for a wall mount for my LG 47LV3530.
The manual suggests using the LSW400BG mount, which looks very slim behind the TV.
I found the SANUS VMF308 while searching online, and it looks very well designed and slim.
Then there is the Ellies Sanus and normal mounts like this one.
I'm leaning towards one of the first two mounts, just not sure where to find the LG mount.
Any suggestions or advice about wall mounts I should know would be appreciated :)
Thanks,
FB
You will probably pay 2 to 3 times more for the LG mount when compared to the other brands. Unless you going for a fancy tilt/adjustable type mount, I would just get a standard slim ellies/or whatever else the closest store has in stock. Should be around 300ish
Not looking to be fancy with tilt/adjustable mounts, just need something slick and slim to keep the swambo happy. Don't think I will mess around with the TV as soon as it is mounted on the wall.
