Wall mount plastic screws for panel heater
joker08
I cant seem to find the below. Its wall mounting plastic nail for a Salton pannel heater. There were 4 now only this one is left.
Where can I find one or what's the best alternative? it has to be plastic, I am told that I cannot use metal.
I have all of the 4 wall plugs, but the rest of the three nails are the ones broken.
The last one of these I installed the plug was plastic like that but it has a normal metal screw going into it with a cap after the fact to cover the screw.
Unfortunately for you I threw all of these plugs away from the previous one that cracked when I replaced it.
What did u end up using then ?
there is no reason you couldnt use a metal anchor screw there, i would probably just use a snap on plastic screw cap to make it look tidy, will also insulate between the panel and the screw head
Yeah I think the pertinent part is the metal bits not touching any internals of the panel.
But the screw goes into the anchor which is inside the panel.
I managed to buy some from Chamberlain's in Centurion a few months ago
I never found for our one wall panel heater so cut up some plastic tubing I had in the garage, found some washers and used a normal wall plug with longer screw. Looks a bit kak with a metal washer showing but it works...
