Water Damaged: macbook air
JV_011_
Centurion
Hi Guys, I have a water damaged macbook air that i need to fix. Can anyone recommend a reputable repairer apart the istore.
So it is a Macbook Water now? Didn't know they had different elemental versions.
Also, surfing the web with your Macbook doesn't include any water contrary to popular belief.
Remove battery immediately to stop corrosion caused by electrolysis.
If you have those P5 Pentalobe jobbies, where the hell ya get 'em?
I think it had already been cleaned by the apple store guys inside, i left it alone for a few months and this morning i took it out, plugged it in and to my surprise "It works". I just have to reset my password and upgrade the OS and i am good to go.
Get them from the flea markets, cellphone repair shops, eBay, BidorBuy, Aliexpress, Banggood, Amazon, back of my cupboard.
