Hi Guys
I really need your help on this one. I have been experiencing a very weird ADSl speed issue. Let me start at the beginning.
I stay in Pretoria, on the Erasmuskloof exchange.
I had an 8meg stable line for more than 6 months, running Mweb platinum 10meg uncapped account through Openweb. Line worked fine, no issues.
Openweb stopped reselling the Mweb platinum accounts, so I was moved to a Vodacom Business ADSL 10 meg uncapped account.
Then all hell broke loose....
My line would still sync at 8 meg, but download speeds were very poor (about 10-15k/sec down vs 850k/sec previously). The upload speed would actually work at full speed (+- 55k/sec up).
Contacted ISP and was moved to IS based uncapped account - same problem.
ISP tested both accounts and accounts tested 100% at there end. I also tested the accounts at a different location with full speed. ISP also gave me new accounts for IS and VB - still the same problem.
If I however use a capped IS based account (afrihost free 1gig), then full download speeds anytime.
This sounds very much like a Telkom routing issue to me. Any other ideas?
And more to the point - how do I solve this? The Telkom ADSL helpline is not very helpful. Resetting DSLAM / PORTS did not do a thing.
Anyway, my router connection stats:
Mode: ADSL2+
Line Coding: Trellis On
Status: No Defect
Link Power State: L0
Downstream Upstream
SNR Margin (dB): 10.8 12.1
Attenuation (dB): 40.0 22.5
Output Power (dBm): 16.5 8.6
Attainable Rate (Kbps): 12432 956
Rate (Kbps): 8031 639
MSGc (number of bytes in overhead channel message): 59 12
B (number of bytes in Mux Data Frame): 250 19
M (number of Mux Data Frames in FEC Data Frame): 1 1
T (Mux Data Frames over sync bytes): 1 4
R (number of check bytes in FEC Data Frame): 0 0
S (ratio of FEC over PMD Data Frame length): 0.9960 0.9877
L (number of bits in PMD Data Frame): 2016 162
D (interleaver depth): 1 1
Delay (msec): 0 0
Super Frames: 259649 259647
Super Frame Errors: 2475 28000
RS Words: 0 0
RS Correctable Errors: 0 0
RS Uncorrectable Errors: 0 N/A
HEC Errors: 1648 419
OCD Errors: 2 0
LCD Errors: 0 0
Total Cells: 79608922 425963629
Data Cells: 484452 629648205
Bit Errors: 0 457
Total ES: 2323 1258
Total SES: 0 1062
Total UAS: 16 4362
Please help guys!
Regards
Mode: ADSL2+
Status: No Defect
Downstream Upstream
Delay (msec): 0 0
RS Words: 0 0
OCD Errors: 2 0
LCD Errors: 0 0
Bit Errors: 0 457
Total ES: 2323 1258
Total SES: 0 1062
Total UAS: 16 4362
Please help guys!
Regards
