Dolby
- Jan 31, 2005
I moved to Northriding about 7 months back and to my horror, Vodacom data was non-existenent rendering my contracts useless. The phone would display EDGE, but it wouldn't even connect - ZERO throughput.
I took out an 8ta 10GB special for my data needs, but at the same time moaned daily to Vodacom about lack of service. Someone was sent out, verified no signal, and Vodacom installed a booster/repeater on my roof - which allows me to use Vodacom data once again (On my iPad)
Tonight I thought I'd try both cards in my PC and get signals strength, RSSI etc - but I don't understand what gives performance? Tested with a 21mbps E1820 modem, my results :
8ta ... 67% HSDPA+ signal /-93dbi. Speedtest.net gets 80ms ping,and download at 3mbps (peak at 6+mbps)
Voda ... 99% HSDPA+ strength / -65dbi. Speedtest gets 150ms ping and download at 1mbps (peak at 1.5mbps)
These have been consistent with results from the past few months - so neither provider had a tower issue or anything negative impacting. On paper, the Vodacom should get great speeds - but it doesn't. I'm not too phased as it's my iPad data ... but I'm curious as to why?
