What is the difference between these two on Loot?
Devo1
Worcester
Goodmorning
This may sound like a stupid question, but I would appreciate the help.
I ordered Call of Duty: Infinite Warfare this morning from Loot:
https://www.loot.co.za/product/call-of-duty-infinite-warfare/bgjd-3761-g560
After payment I saw that it shows Platform: Blu Ray
Will this still work on my Xbox One S?
Because I see there is another one listed on the website as per the link below:
https://www.loot.co.za/product/call-of-duty-infinite-warfare/cvbb-4494-g020
This one just says Xbox One (without the Blu Ray part)
What is the difference between these 2? I know some Blu Ray Movies are region locked, but games as well?
So will the one I ordered work or must I ask them to change to the 2nd one? Im quite clueless regarding these technical stuff.
Thanks a million
I think the games are region locked (iirc). You may also need to install the Blu-ray app.
I have no idea!
I just find it strange that they list the same game twice (R1 difference in price). The one shows Xbox One: Blu Ray and the other just shows Xbox One.
I phoned them but the lady said I should email them and they will send it to their technical team to find out what is the difference and which would work.
On the order page it shows Xbox One so it should work.
If it doesn't then have them exchange it.
All XB1 discs are Bluray and they're not region locked AFAIK...
Goodmorning
Thanks a million
they both show as xbox one so no difference really
So i doubt it wont work
Loot just got back to me and they say they are the same and both will work on any Xbox One.
Thank you for the replies guys.
Loot and Takealot sometimes don't update their listings and just create new ones. So they end up with two of the same. Just order the cheapest one.
