Are you having iPhone 3G & 3GS battery shortcomings? This solar power charger is just right for you, it has a high capacity 2000mAh battery which let you charge from a solar source and store the power for your phone when you need it most. It can provide one full charge for your device and will recharge itself through the solar panel mounted to the back of the case. Go green as it naturally converts clean and green solar energy directly from the sun without using artificial methods that can cause global warming. So what do you think? You can go and buy here:
http://www.gindart.com/buy/2000mah-solar-battery-charger-case-for-iphone-3g-3gs-p-2145.html
