Where to report a Cell tower Problem
Peder
Hobbit
Pretoria South Africa
Hi Guys
Where do i report a cellphone tower problem? seems the cellphone tower near our house was knocked out by the lightning since i have VERY bad reception as of this morning.
Regards
Peder
The cell companies' monitoring system will have flagged it already, especially if they are sharing the site with other operators!
If not, visit their website and log it there.
Hi Guys
Regards
Peder
Hi Peder
Have you logged this ?
Regards
VodacomData
nope i haven't sorry where should i log it?
Since our reception is really bad, just haven't been home today.
[email protected] or 082155
If you logging it with [email protected] , then remember to include the following:
CELL NUMBER TO LOG FAULT WITH - i would recommend using your normal cell
CONTACT NAME:
ALTERNATIVE CONTACT NUMBER:
PHYSICAL ADDRESS WHERE PROBLEM IS OCCURING - And not, "Everywhere is not a answer!" :-)
FULL DESCRIPTION OF FAULT:
U will be mailed a ref number within a few minutes, and another within 24 working hours once the fault has been logged with network.
Regards:
Hi
i can check the tower as well , what is the number in question please
Regards
VodacomData
