WIndows 10 1803 audio problem
LiengLiengZA
Dronkenville,Vereeniging
Good morning My'bbers,
I did the update to 1803 on Windows 10 day before yesterday.
Came home last night switch on PC and have no audio on my headset on the front panel.
When plugging in the headset at the back it works perfect.I read on the webz that this is a common problem.
There is a fix with regards to changing microphone settings.But that didn't help.
Also tried updating Realtek drivers to no avail.
Has anyone else encountered this problem and is there anyway to fix it or should I wait for patch.
Cause I don't want to revert back to 1709.
Disable front panel jack detection via the Realtek Audio Manager.
That should do the trick
When I updated windows, plugging it to the front or the back didnt work. I tried everything on every site on the internet. I ended up installing a sound card and then only did it start working.
I hope you come right!
