Windows 7/Xp mix up!!help
ViciousClone
Western Cape
Hi all
i have windows 7 installed on my system,i re did my friends HDD and he wanted XP
the hard drive had bad sectors,so fixed them(his drive being slave) and inserted XP cd and chose his drive and installed XP
took it out and back in his system and working 100%
BUT!!!! turned my system on tedaaa...i get this message "windows could not start because of a computer disk hardware config problem"
So i press f8 and tried to choose my windows 7 OS...but it doesn't show anymore but only XP OS :/
what can i do to roll back the OS or get my windows 7 back again??
thanks!
You left your main drive in and still master while installing another OS to slave?
Quick Google:
(windows 7 boot records)
http://www.tomshardware.com/news/win7-windows-7-mbr,10036.html
I think XP messed with the Master Boot Records of 7.
haha found the same site ! but thanks :)
Site did help! luckily :D with CMD and then bootrec.exe /FixBoot
dodged a bullet! it rebuilt my OS list ,instead of seeing windows XP as my only OS, that command redid my list of OS and found the original Windows 7 list again..
Thanks :D
